2009 9-3 Combi 2.0. Gifted the wagon with a new set of tires and decided to change the rear shocks, looked like a quick and easy job. Not so much. The top shock nut was rusted and couldn't get it off so I decided to remove the mount and cut the nut in the vice where I had more room. Ended up breaking one of the top mount bolts (the only one with a full hole) after it had turned out several turns, and the upper shock mount broke at the same time. Ordered new upper shock mounts but cannot find the upper mount bolts. Can I use any bolts the same length/pitch (threaded all the way to head), or does someone have a source to the correct bolts? Thanks in advance.
