1 - 12 of 12 Posts
I did my cold air intake now i have a almost new sport exhaust cat back swopping with a customer because they want a stock one and im also redoing the timing with the 210 HP cam tools because i have it set up for 175 HP right now because its a base but i just put the High pressure turbo in so all i need is injectors and i will tune my car with my computer and oh man stay out of my way lol
cc93: *looks in rear view mirror* "what is that thing coming?! Is that a..." *VROOOOOOOMMMMmmmm....* *whooshing sound as car drives by* "yes... it was a V6..." *looks away into the distance in silence"
The end :)
P.S. No V6s were harmed or tuned in the making of this history :)
cc93's car will probably be significantly quicker than an untuned v6 once he has everything in place (and good software). The untuned v6 is not that quick you know :) endless discussions on this in here.
cc93, what power are you aiming for?
The 2.0 may not be that much slower then the v6. its the immediate torque you recieve in low rpms that is the thing I miss. Do enjoy the more defined turbo kick in the 2.0 though.
HIS car is so fast, its making him forget how to use periods and capital letters!
iirc the engines are identical, only diff is the lower pressure turbo on the lin compared to the high pressure turbo on the ARC and Aero/Vector's and of course the tune
the difference between the t and T is the different turbos and the cams
http://www.saabcentral.com/forums/showpost.php?p=324811&postcount=8
Decided to dig up some part numbers of items which vary between models as I'm sure people will soon be swapping and upgrading!
The Turbocharger was changed for the Aero engine.
B207L: 12 755 106
B207R: 12 788 719
A myriad of tubes and gaskets were changed for the different turbo, so upgrading to the Aero turbo would be tricky, but do-able. I have part numbers for all the various tubes etc.
The "R" engine got a different intake manifold.
B207E-L: 55 352 121
B207R: 55 352 128
Also a different PCV valve:
B207E-L: 12 786 376
B207R: 12 797 658
The "R" engine again got a different fuel rail and injectors:
Fuel Rails:
B207E-L: 12 790 824
B207R: 12 790 826
Injectors:
B207E-L: 12 801 655
B207R: 12 801 656
The "R" engine also got a different flywheel (55 353 856), and the "L" and "R" engine share a screw which has a different part number on the "E" engine.
All of the bottom-end internals appear to be the same including connecting rods, pistons, crankshaft, and bearings.
The "R" engine got a different cyllinder head assembly:
B207E-L: 55 353 477
B207R: 55 353 478
The reason for the different assembly part numbers may only be a result of camshafts inside the head which were changed. It may also have a different casting. There is no EPC listing for the bare head itself.
The "R" engine got different camshafts on both intake and exhaust, but all other parts inside the head appear to be the same. Here are the "R" spec camshaft part numbers. (I'm assuming no one wants the "E" and "L" PNs.)
Intake: 12 792 364
Exhaust: 12 788 844
The "R" engine also got a different valve cover. (12 797 659)
Nearly every engine/trans combination got its own unique clutch. This may be why lower model versions with PPC upgrades experience clutch slip.
Gearbox assemblies are the same for all B207 engines. Lots was changed between 5 and 6 speed transmissions. (Almost everything that touches it in fact ... even some of the engine PNs vary from it.) It will be hard, but not impossible, to upgrade after the fact.
The "L" and "R" engines got a beefier driveshaft than the "E" engine.
The "R" engine got beefier brake rotors, the diameter of which has already been mentioned. What has not been mentioned is that they are also 28 mm thick instead of 25 mm on the front as in the rest of the models.
Also, in everywhere BUT the US and Canada, the front rotors are 12.4" instead of 11.9" in diameter on the "R" engine cars.
There is also a limited amount of part number confusion regarding brake rotors. For instance PN 24 435 132 appears to be for Aero chassis only, irrespective of the engine ordered. (All of the Aero's should have the "R" engine, but some of the other cars have that engine too.)
The Aero also appears to get it's own special brake housing. (Caliper.) And the carrier spec appears to depend on the size of the wheel spec'ed for the car, as does the spring-clip. :-?
Pads for the front brakes on Aero models with 16" or larger wheels is PN [12 802 167] and is different from the standard brake pad kit.
That's all I can dig up for now. Enjoy and keep on Saabin'
Adrian~
1 - 12 of 12 Posts
