Over the weekend I lowered my 9000 Aero. All went well except now my ABS light is on in the dash. Do you think the sensor was damaged somehow in the swap? I disconnected each rear sensor when I was switching out the rear springs and shocks, but I didn't think there was any sort of reset that I needed to do; I just put them back in the holes and screwed the bolts in tight. Any experience with this?
Cheers
check all the wiring first. pull back the sheaths make sure no wires look stretched or broken. check connectors good ktoo pin terminals are alaways prone to spreading which will cause bad connection. if all looks good check resistace on each sensor probably should be around 1000ohms. dirt mudd or anything else around hub where sensor is reading can cause problems. all abs sensor is is a magnet so check and make sure they're still magnatized.;) magnets do get weak over time
