I've got a bendy turbo already, but have swapped it onto a garrett watercooled core and used a garrett rebuild kit along with 360 thrust bearings, quality of the casts is'nt great but hopefully when i get the 8v turbo up and running it'll do the trick, for the cost (about £220 for a large T3/4 hybrid) i could afford to rebuild it every 10k miles.
The core was an exact copy to the mm of the garrett oil cooled core, the compressor wheel was a descent cast, turbine had a few imperfections and a lot of material removed to balance in compared to a garrett turbine (had both garrett T3 and the bendy one in bits comparing the quality).The compressor housing was relatively poor, but could be cleaned up, turbine housing was a bit more of a solid cast but stuff like the WG housing studs were a slightly different orientation to the standard Garrett T3.
I think one of you US guys should bit the bullet and order one, be the guinea pig!
