Hello,
I am working on a 2002 9-3 SE convertible. I hope someone can identify this indicator light and describe it's function. The top item with the two red LED's. There is also a multi position rotary switch located in place of the blank switch plate next to the Instrument light dimmer. This seems to be an aftermarket item since it was directly wired to the switch and wires needed to be cut in order to replace the dash panel in this car. Unfortunately when I reassembled the dash the headlights are always on even with key removed and High beam indicator doesn't seem to be functioning normally. Obviously this is some system related to the headlamps but not sure. Any help would be appreciated.
Thanks
Jim
Thanks
Jim
