So,
For a very long time, over a year, I have had this very slow coolant leak. It does not leave any drips while running.
Well, I thought it was my radiator (hit an animal, bent my intercooler, and thought maybe it screwed up the radiator. I also saw some crustiness and discoloration on the top of the radiator. Pictures attached)
But today, I had just started the car before it had time to warm up, and wanted to look underneath to see if I was leaking trans fluid as I had just replaced the axle and wanted to make sure I tightened the drain plug as I drained and saved the fluid.
But, when I did that, I noticed some fluid on the downpipe, right after the cat. Shut off the car and jacked up the front, crawled under and sure enough, it was coolant. Tried looking up but couldn't see much.
I have a picture of where I could see wetness. Its not the best picture, but that is the most I can see up to where it was wet.
