1 - 17 of 17 Posts
I thought that I had a bad ECU, and I may, but I see that I may also have another problem with the UEC module(s) as I am getting a traction control error message.
I can get these from a junk yard near me. Are they easy to replace?
what car,engine..
Discussion Starter #10
have you cured the P0687 code you were getting in the other thread..
No. The P0444 went away, but the P0687 still comes back as do the stability control and traction control messages.
The new thing yesterday was the alarm going off.
Sounds like a bad component is draining it. Get multimeter out.
Discussion Starter #15
I charged the battery, and I am now up to 12.4 volts. I also changed the ECU relay today. The car drove fine and did not throw any codes. I'll try to go on an extended drive tomorrow to test further.
1 - 17 of 17 Posts
