1 - 2 of 2 Posts
Hi all,
have a strange issue. Following codes showed up on Tech 2:
UEC B3867 04 and B2585 04 Front Parking Lights (Left and Right). Both bulbs were out, but when bulbs were replaced the lights worked but the codes would return after they were cleared. Any ideas? Where should I start?
Thanks!
Same here, I've tested all the wiring and harnesses, swapped out bulbs, added/re-added UEC, etc. and this one just keeps coming back. Beginning to think it's a result of adding fogs to a Linear, messing with DRL, ROW adding the BCM,UEC & REC w/ T2 and changing out the light switch in order to gain both fog buttons. Meaning the ECU just doesn't like certain combinations of these things that aren't supposed to be "upgraded" without seeing it as an open circuit or when closed, the light doesn't operate as it should.
1 - 2 of 2 Posts
