1 - 20 of 107 Posts
· Registered
I went to your site and used google translator and got a pretty good idea of what you were doing.
Are you very experienced with making fiberglass enclosures or could an amature do that also?
· Registered
Some updates
Stock door and speaker
HERTZ HV165L vs Bose midbass
The difference between new and old speaker
Place will be in the plastic ring state dynamics, to get this ring, you need to carry out some violent actions :cheesy:
Get the ring of plywood and set the speaker
Doubts in the installation of dynamic stiffness at plastic ring destroying additional fasteners dynamics bolts with nuts to the iron door
Attach the door trim
· Registered
Wow, looks really professionnal install. Now I understand more about the rattles when I look at the inside panel of the doors! They could have uses a lot more sound insulation. Where do you buy that material that you've used?
· Registered
Are you just using loc's then to get the low level signals?
Usually deadening the plastic trim on the inside is not effective. The material is meant for metal to stop vibrations and resonant noises.
I hope your not running the ground to the battery.
1 - 20 of 107 Posts
