1 - 12 of 12 Posts
I have a B234i N/A engine in my 1998 900S. I want to put a turbo in it, but I want to do it right (e.g. changing pistons, cams, etc. if I have to), and I would really like to know what all I'm looking at replacing, the best place to get these parts, and how much I should be prepared to spend.
The short Answer is it is easier and cheaper to buy a turbo model.
A few guys on here have done it.
Here is an old thread I found http://www.saabcentral.com/forums/showthread.php?t=26428
There is others
Easiest way is to find a Turbo model as a parts car and swap everything over. Not sure which pistons are in the 234i engine. That will be a limiting factor as well as the compression ratio as the NA cars have a slight bump in compression, as well if they're cheaper quality like Hypereutectic. Personally, I don't think it's *that* hard to do if you're good with a wrench and your NA car is in really nice condition. Technically, you can put a turbo on anything ;ol;
been there, done it. not worth it reliability wise
i have threads about the whole process (search my user name)
you find the performance cap very early on with that setup
bout 210whp, and 260wtq is what you will see
While I would agree that it is not worth it from a performance stand point because you top it out pretty quick without spending a fortune... I say if it interests you, go for it! If you are looking for more details grkguy89 and myself have both done this in the past few years so we have a few notes ;) PM me for details.
The only HP limiting factor he has is the reciprocating assembly in the b234i, right? If he finds a running b235r for a good price, why not swap engines?
I don't think the 234i has piston cooling jets. Pistons are domed rather than dished. Cams are different. Intake manifold is different. Wiring harness is different. You have a maf rather than a map. Then you would need intercooler and piping and all the goodies
Sent from my DROIDX using AutoGuide.Com Free App
they do have cooling jets, and have flat top pistons like a turbo model.
cams are not drastically diff
Mine are dished. NA should be flat to bump up compression ratios
Just buy an SE and save yourself a whole lot of drama. Then throw a stage 3 at it.
1 - 12 of 12 Posts
