Good luck. Since you just had head work done I would suspect that your water leak is related. I wish someone would comment but I don't believe that a blown turbo will put water into your oil. Seems like a bad design even given they are water cooled. Saabs have precisely engineered heads that are prone to warp unless torqued correctly and in the correct bolt order.
I'd highly recommend driving it up on ramps, disconnecting the cat from the turbo (3 nuts), loosining the pre-catalyst mount (2 bolts) and using a flashlight and mirror to look at turbo fans or just swab it with a q-tip. No oil , no turbo problem. Then go after the shop to redo your head gasket. BTW, anti-freeze in the combustion chamber will eventually crack or damage your head. Needless to say water in your oil will trash everything.
Thanks CliffC.
The car is now in my garage, which is being heated up with outside temps in the 20's today, so I will be first checking the water-oil issue.
My plan of attack is to do a compression check on each cylinder. Then do the turbo inspection as you suggested.
The whole "frothing" of the oil has happened in the past 4 days or so. As I mentioned, I did an oil change last Friday and there wasn't any evidence that I could see of the water-oil mix. However, I did a 400 mile round trip getaway and that's when the smoking issue became VERY evident, which became worse and worse each day.
The smoking on deceleration was indicative of bad valve stem seals at first. Just a puff or two. But it progressively got worse. A little smoke on acceleration and a lot of smoke on deceleration. And doing the searches more or less pointed at the turbocharger.
I haven't seen a scenario of a bad head gasket producing the same problem, but that doesn't mean it can't be the problem.
Have you, or anyone else, seen where the smoking like this would be the head gasket?
When I say it resembles a mosquito control truck, I mean there's a LOT of smoke for about 2 minutes when I first start it up now. Before it was "minor" smoke. Then it evens out until I drive it.
OK, I'm rambling now and need to get out there. lol
Thanks again for your input.
- Mike
