sorry, the search function isn't working for me.
what kind of turbo is on my car? I've seen people mention td04 which I know is a Mitsubishi, but that only describes the hot side. Is it a 16t, 18t, etc...??
I believe it's a 15T...or maybe 15G? :confused: Someone help me out here.
dont know if anyone knows, but does the td05 have the same exhaust flange as the td04, and will it fit? my friend has a turbo the he took off his eclipse gsx and i thought about putting it on my car. it is in good shape, plus it is a centimeter larger than the td04
I have no idea if it would fit.
But if you want to upgrade the turbo, I'd stick with the known choices with specified upgrade stages, rather than the unknown, as I would think you would definately need to go the custom ECU map route with this turbo, if it did indeed you could get it to fit.
95% sure it will not. tdo5 has different manifold flange. Not to mention you would need to change your downpipe. And then get a custom map for your ecu.
