1 - 11 of 11 Posts
where do i tap into to get the best turbo reading. im looking to install one but idk where i should go. its a t7 motor. thanks
Theres a lil hole already there with a rubber seal you can pull of, behind the steering wheel colum it's really not that hard I got so much stuff running threw there
technically, to get a proper reading you should tap directly off the intake manifold without T'ing into another line. but, if accuracy is not something that matters you can come off pretty much any vac line.
Where's there an unused line on the manifold?
Take a drill, a tap and threaded barbed fitting and make one. I'd advise taking the manifold off first, dont want any drill burs getting in the valve train/cylinders.
No disrespect, Jake, but to heck with all that! I'm down with just using a "t".
1 - 11 of 11 Posts
