Im trying to establish an easy way of testing and confirming any changes to the standard engine when you change exhaust parts or air filter parts or even ecu without going to a roll road
I know that an ecu upgrade gives xtra power but im firstly trying to see what happens without ecu change if possible to check this.
For example, people say that if you change the exhaust, air intake filter, pipes etc then you will gain some xtra power, or at least get a faster turbo spool up which as far as im concerned is still a power gain as you will be putting the same power on the road at a quicker pace . I am also aware that there may be no changes at all .
At this moment, i am concerned with the untuned engine and what are the effects of just changing the exhaust tail output to a sporty output
then later, also the effects of changing the air filter box to a cone.
The bottom line is that if the exhaust or air intake is made more efficient, then it must have an effect on engine performance.
So i would like to put this idea to you about a possible method of measurement to check the changes to turbo spool up.
If i go along a flat road at 30mph in 5th gear, then floor it, i can monitor the speed , rev counter and boost gauge, ambient temperature and i could also use a stop watch to time this measurement.
What i would do is make a note of when the maximum boost is achieved, ie the boost gauge hits the red. ( im aware the boost gauge is ecu driven)
For example say my full boost is reached about 55mph and around 2000rpms , at a temp of 16 degrees here are my questions ....
If turbo spool up is improved, then what effect does it have on the following parameters
Time - It seems obvious that it will reach full boost in a quicker time
Speed - Will it also reach full boost at a lower speed ?
Rpms - Will it also reach full boost at lower rpms ?
Temperature - What effect will ambient temp have on the gauge full boost performance ?
