21 - 35 of 35 Posts
91 9000 Abott
I am not completely sure of all mods because car was seconhand.
Large valve Abott head.
Abott LSD.
Massive Abott intercooler which dwarfs radiator.
Koni adjustable shocks.
Abott springs.
Reprogrammed ecu.
Manual boost valve.
Large bore exhaust.
Brakes largely standard but grooved on rear.
Not sure of clutch but feels like comp type.
I removed the Azek 17 wheels with Michelin and put 15 with Yokahama.
I put poly bushes on the front wishbone as the existing were worn. Would like to change all to poly eventually.
Abott told me they expect about 260 bhp but did not measure.
The car seems extremely fast to me compared to my BMW 850 which has a 5 litre v12.
Presently I am repairing the engine which had a blown turbo and head gasket. Also looking to lighten car by removing anything not essential. The seats are rather heavy, The electric sunroof can go. Radio CD and speakers can go. Lots of glass could be replaced with acrylic. All central locking can go. I am looking into a roll cage but a bit hard to afford, does anyone have plans to make one. Thought I would put bars across the front and rear suspension mounts. A fuel cell in place of the tank might be good. Some sort of aerodynamic improvements would be nice.
Interested to exchange ideas with anyone with similar ambitions. Hoping to turn what was a fast car into an even faster one. Anyone who knows the car would be welcome to get in touch apparently it belonged to Abott Racings photographer.
Model: Saab 9000 Aero
Year: 1995
Turbo: GT28RS
Pistons: Stock
Rods: stock
Crank: Stock
Block: Stock
Head Bolts: Stock
Head Gasket: Stock
Head Valves: Stock
Head work: Stock
Valve Springs: Stock
Lifters: Stock
Cams: Abbott Racing Stage 1
Exhaust Manifold: Stock
Intake tubing: Abbott Racing big delivery pipe
Downpipe: Aerodyte 3" Modular Downpipe
Exhaust: Abbott Racing 3" CAT back stainless system
Intake: Blitz Sonic Power cone filter with 3" stainless intake pipe
Blow off valve: Forge Competition DV
Wategate/WG actuator: GT28RS (came with)
Intercooler: Abbott Racing
ECU tune: T5 Suite custom map by Faero
MAP sensor: 3 BAR
Boost Control: Stock
Turbo Pressure:
Torque mount bushings: Poly
Bottom mounts: Poly
Oil: Mobile 1
Fuel Pump: Walbro 255lph
Fuel injectors: Siemens Deka 630cc
Fuel Rail and Lines: Stock
Turbo Pressure: 1.6 bar
Flywheel: Abbott Racing Lightened flywheel
Clutch: Sachs uprated pressure plate with Aero friction disc (fitting next week)
Transmission Gearset: 4.05 box
Transmission LSD: None.....cant afford it!
Tranny mount: Yellow Polly
Gear shift lever: Stock
Oil: Amsoil
Front Brake Discs: EBC grooved & Dimpled
Rear Brake Discs: EBC grooved & Dimpled
Front Brake Calipers: Stock
Rear Brake Calipers: Stock.
Front Brake pads: EBC Yellow Stuff
Rear Brake Pads: EBC Yellow Stuff
Brake Lines: Goodridge Braided all round
Brake fluid: RBF600
Suspension Shocks: Bilstein B4 front and B6 rear (fit next wek)
Springs: Apex (fit next week)
Strut Brace Front: Elk parts
Strut Brace Rear: None
Sway bar front: Stock
Sway bar rear: SAS rear ARB (fit next week)
Bushings: Abbott Front rear polly wishbone kit
Wheels Brand: Team Dynamics Pro Race 1.2 in Black
Wheels Offset: 35
Bolt pattern: 4x108
Hubcentric adapters?: yup
Wheel Size: 17x7
Tires Brand: Bridgestone Potenza RE050A
Tires Size: 225/45/17
Other custom mods: Sandy Beige seats, Beige/Black door cards. Black spoiler.
Horsepower range: 350-360 bhp...need to be dyno'd
Best mod: GT28RS turbo:evil: But cheapest bang per buck is easily the gearbox swap for the 4.05 (4.45 was mental...just mental:eek:)
Worst mod: Hate to say it but so far the cams! Bigger turbo could help.....
Next mod: Fit the above suspension/ clutch upgrades. N/A manifold swap, heat plate delete. Fit some custom door speaker pods, fit Focal speakers and 1 more amp! cover all the walnut parts with 3M Di-Noc carbon film, tint windows, paint brake callipers yellow. Swap the bumpers for black ones to carry out the silver/black theme. Possibly swap the GT28RS for a GT3071Rwg in about 6 months:evil:
Give it a good clean
1995 9000 "Super" CS
Model: Saab 9000 CS Turbo.
Year: 1995
Turbo: NOS TD04HL-15T #6 Exhaust Housing
Pistons: Stock
Rods: Stock
Crank: Stock
Block: Rebuilt by "DeLorean" and myself
Head Bolts: Stock
Head Gasket: Stock
Head Valves: Stock
Head work: NEW stock
Valve Springs:Stock.
Lifters: Stock Hydrolic.
Cams: Exhaust = 1985 900 Turbo, Intake Stock.
Exhaust Manifold: Stock T25.
Intake tubing(like to throttle body, from filter to turbo):stock.
Downpipe: Top 1/2 of first gen. JT 3" - rest custom
Exhaust: Custom 3 inch. Sports cat, magnaflow straight through muffler (no baffles)
Intake: Drilled air box, K&N filter element.
Blow off Valve: Atmospheric Forge, 20psi spring.
Wategate/WG actuator: Stock.
Intercooler: Stock.
ECU tune: EPL Performance Stage 4 Tune.
MAP sensr: Stock.
Boost Control: T5 BPC added
Turbo Pressure: 10.5-20ish psi.
Torque mount bushings: both poly.
Bottom mounts: Front Lower = OEM Hydraulic, Rear Lower = Solid
Oil: 0W-40 Mobil 1 Full Syntheic
Fuel Pump: Scan Crap.
Fuel injectors: Stock.
Flywheel: Flexplate...stock.
Clutch: N/A @ this time
Tranmission Gearset: Stock, Warrenty Replacement @ 40K
Transmission LSD: Stock.
Tranny mount: Poly.
Gear shift lever: Stock unmodified.
Oil: ATF (changed every 9,000 miles about)
Front Brake Discs: Brembo
Rear Brake Discs: Brembo
Front Brake Calipers: Stock (Rebuilt)
Suspension Shocks: Bilstien HD's all around.
Springs: OEM Aero springs
Strut Brace Front: none.
Strut Brace Rear: none.
Sway bar front: SAS.
Sway bar rear: SAS.
Bushings: stock.
Wheels Brand: Stock 1998 Aniversary Wheels
Wheels Offset: Stock
Bolt pattern: Stock
Hubcentric adapters?: No
Wheel Size: 16"
Tires Brand: Goodyear/Hercules
Tires Size: 215/55/16
Other custom mods: Beartracker Scanner, Whistler 1665 Radar Detector, Boost Gauge, Aero Body Kit, 9-2X Aero Exhaust Tip, Leather Aero Door Panels
Need to update this but cant edit any posts :confused:
Year: 1995
Turbo: GT3076R 0.86
Pistons: Stock
Rods: stock
Crank: Stock
Block: Stock
Head Bolts: Stock
Head Gasket: Stock
Head Valves: Stock
Head work: Stock
Lifters: Stock
Blow off valve: Forge Competition w Green spring & couple shims
Wategate/WG actuator: Forge with Red Spring
Intercooler: Abbott Racing (soon to be 3" Chinese Ebay special)
MAP sensor: 3 BAR
Boost Control: T7 APC Mod
Turbo Pressure: 1.8 bar
Bottom mounts: Poly
Oil: Mobile 1
Transmission LSD: None.....skint!
Gear shift lever: Stock & shagged!!
Oil: Amsoil
Front Brake pads: EBC Yellow Stuff R
Rear Brake Pads: Pagid
Brake fluid: RBF600
Suspension Shocks: Koni
Springs: Abbott Racing
Strut Brace Front: Speed Parts
Sway bar rear: Abbott Racing
Wheels Offset: 35
Bolt pattern: 4x108
Wheel Size: 17x7
Tires Brand: Toyo R1R
Tires Size: 235/40/17
Other custom mods: Sandy Beige Aero front seats, Rear seat removed, Beige/Black door cards w c/f vinyl door caps, c/f vinyl dash, Black spoiler.
Horsepower range: 450+ bhp @ 1.6 bar (could be closer to 470 now the boost's turned up)
Best mod: Adding thinners to the mix ...rocket fuel this stuff ;)
Worst mod: Faffing about with Aero seats...should have got buckets
Next mod: Bigger Intercooler, Fit the tubular manifold off a Nissan Pulsar, Fit bucket seats, Fit Bilstein B6 & Eibach springs, Fit SAS arb...lots of fitting!!
model; 9000 cs carlsson 2.3t
year; 1992
turbo; squitty t25 garrett
pistons; stock
rods; stock
crank; stock
block; stock
head; stock
exh manifold; stock
intake tubing; stock
exh downpipe; 3" homemade with no cat all the way to the centrebox
intake; home made high flow filter
blow off valve; stock bosch being as competition dump valves don't do a thing
w/g actuator; 12psi
intercooler; stock
ecu; jetronic lh 2.4.2 with std carlsson map
injectors; stock
fpr; 3 bar stock
boost control; forge mbc with my own modifications
boost pressure; 22psi (1.6bar)
transmission; 5 speed manual 4.05 ratio.
suspension; koni adjustables with abbott springs
bushings; polyurethane
wheels; stock 3 spoke aero lite
tyres; 205/50 r16 with event up front and some other budgets on the back
brakes; stock with fresh brake fluid and new bosch lubricant instead of copper slip
body; stock
electrics; led eye level brakelight with modified lampcontrol ecu to compensate, led dash lights, led sidelights, led no plate lights and interior lights
best mod; all of it
worst mod; t25 turbo
next mods; brakes and new concept twin turbo designed by me, 3.5bar fpr, green injectors, piggyback rear arb, lsd, more led lighting.
Not a t25 in fact. It's a 15t td04. Gear ratio is now 4.55. This car has been smashing 4.05 boxes and I still want a bigger turbo. Maybe I could try 18t wheel.
Model: Saab 9000 CSE 2.3 LPT
Year: 1996
Turbo: Stock
Pistons: Yes, four
Rods: I expect so
Crank: No, electric start
Block: Yes
Turbo Pressure: Probably way lower then it should be.
Torque mount bushings: both knackered I expect.
Fuel Pump: Possibly faulty?
Fuel injectors: Clogged
Fuel Rail and Lines: Stock but I cleaned them up and repainted.
Front Brake Discs: Scarred and rusty
Rear Brake Discs: PFS items, nice and affordable
Rear Brake Calipers: Stock, one side faulty
Suspension Shocks: Very tired
Springs: See above
Sway bar rear: Stock, cleaned and painted
Bushings: All front items due to be replaced, with stock ones
Wheels Brand: Stock
Wheels Offset: Don't even know what that means
Bolt pattern: evenly spaced
Hubcentric adapters?: Hub whattric?
Wheel Size: 15"
Tires Brand: A mix of part-worn items
Tires Size: 195/65/R15
Modifications: None - I prefer my Saabs the way Saab designed them and i'm far too old to care less about having more horses under the bonnet, it goes fast enough already. Having said that, I did change the side repeaters for clear ones as they look better with the standard clear corners. I also repainted or replaced the faded emblems and badges, clean it every weekend and generally look after the car in a slightly obsessive manner. It's my pride and joy and given the money it would have every single issue fixed in a heartbeat!
My Mods
1997 9000 aero
Engine Mods
T5 suite ecu remap stage 5
Abbott intercooler
Abbott Delivery pipe
Green Giants
3 bar map sensor
TD04 TT Hybrid
Braided oil and water lines
Forge actuator
Forge atmospheric dump valve
T7 apc valve
ITG Filter
Full 3ins ss abbott exhaust
Poly bushed upper mount
Transmission
Abbott lightened billet flywheel
Sachs uprated clutch
Modified aero box with quaife lsd and spare aero box with quaife lsd
braided clutch hose
Poly bushed gearbox mount
Suspension
Bilstien B6`s
Eibachs currently fitted
Bilstien B4`s with H&R`s
SAS sway bars
Abbott strut brace
Poly bushes
Brakes
9-5 308mm aero front brake conversion with brembo discs and yellow stuff pads
brembo rears with yellow stuff pads
braided lines
rbf fluid
Wheels
Set of closed nut super aero`s with toyo proxies
Set of carlsson alloys
Set of exposed super aero`s with winter tyres
Set of Oz superlegerra`s with dunlop track tyres
Think that`s it
Total Mods Done!!!
Model: Saab 9000 Cs Aero (Imeola RED-New Paint Job!!)
Year: 1993.5 (Working TCS!!! That's saying alot!!!)
Turbo: Bored out and rebuilt TD04 (Hybrid 19t)!!!
Pistons: Stock with slightly bigger rings after Bore and Engine Overhaul
Rods: Stock
Crank: Stock balanced
Block: Stock
Head Bolts: Stock
Head Gasket: Stock
Head Valves: Stock
Head work: Stock
Lifters: Stock
Cams: Stock
Exhaust Manifold: Stock with ARB Bolts (Spacers removed-Would like ceramic coated?)
Intake tubing: Maptune Silicone IC to Throttle Body Delivery Pipe Tapered from IC to about 3" before TB
Turbo to IC: Maptune Silicone
Downpipe: JT 3" (wrapped with fiberglass mesh fastened with 3+ inch Hose Clamps-would rather have it ceramic coated?)
Exhaust: JT 3" From Race Cat Back to Shorter rear Muffler to 3" Oval Magnaflow Tip
Intake: Stock w/K&N Air Filter and Drilled Air Filter Box in Wheel Well-Good Sound!!!
Blow off Valve: Forge Recirculating SS
Wategate/WG actuator: Forge SS set to 9lb (Green Spring)
Intercooler: ETS 3"
Cooling Hoses: Maptune 7 Hose Set
Coolant: Pentosin RED (A Must Have to prevent corrosion)
ECU tune: JZW Stage 5+ custom tune
MAP sensor: Stock
Boost Control: Stock Working BPC Valve
Turbo Pressure: Base Boost set to 10-11 lbs (9lb Green Spring Bench tests to 10-11 in-situ) , 20 lbs Max Boost
Torque mount bushings: Poly (new Mounting Bracket)
Lower Engine Mounts: PFS Hydrolic
Engine Oil: Mobile 1 5W30
Fuel Pump: Stock
Fuel injectors: 465cc/min 42lb/hour injectors, a set of four Bosch Greeen Giants # 0 280 155 968
Flywheel: Resurfaced Stock with fresh Bolts
Clutch: Spec Stage 2+ with Abbott braided SS Clutch pedal to Slave Cyl Hose
Transmission Gearset: ScanWest Manual Drive 5 speed with 4.05 Gear Ratio (Originally 3.61) Perfect!!(gears swapped from a 91T GM75403)
Other: Scanwest reinforced the Tab Bolt, Shot Peened & Cryogenically Treated Gears , New ARP Case Bolts, extra welds to buff out Tranny box!!
Transmission LSD: Quaife LSD (Awesome!!!)
Tranny mount: Yellow Powerflex Poly
Tranny Oil: The German Stuff??
Gear shift lever: Genuine Saab Taliaferro Short Shifter
Driveshaft / CV: rebuilt genuine saab
Lower Control Arm Bushes: Powerflex Orange Poly (Incredible difference!! Had to have them Bench pressed into new standard bushing housing)
New Suspension Bushes All Around!!
Front Brake Rotors: Brembo
Rear Brake Rotors: Brembo
Front Brake Calipers: Stock Ate w/SS Brake Lines
Rear Brake Calipers: Stock Ate w/SS Brake Lines
Front Brake Pads: EBC RedStuff
Rear Brake Pads: Ferodo
Front Suspension Shocks: Bilstein Touring B4
Rear Suspension Shocks: Bilstein HD B6
Front Springs: Original Aero (Couldn't find a replacement set that wouldn't lower the front end???) Also new Support Bearings
Rear Springs: Fresh Ones from TheSaabSite available at the time, bench tested to originals. New ones were 20% Stronger!! Also, put Genuine Saab Spacers under rear springs like Norman!! New Axle Bolts!!
Other: New Ball Joints, 2 x Tie Rod Ends, 2 x Front Wheel hub Assembly (originals were practically disintegrated!!!)
Strut Brace Front: Genuine Saab Chrome
Sway bar front: 1" (25mm) SAS w/poly bushes
Sway bar rear: 1" (25mm) SAS w/poly bushes
Front Wheels Brand: Carlsson Aero
Bolt pattern: N/A
Hubcentric adapters?: None
Wheel Size: 16
Front Tires Brand (Size): Kumho Ecsta La Sport (205/55/16)
Rear Tires Brand (Size) : Kumho Ecsta SPT (225/55/16)
Boost Pressure/Temp/Air-Fuel/Exhaust: Zietronix LCD and gauges (Still trying to figure out Fuel Pressure Gauge set-up?, tried welding metal bush to top of Fuel Rail/Hose Bolt-Leaked!!!), EGT Bung Welded in middle of Manifold.
Other custom mods: Race Cat positioned after downpipe welded to mid-pipe, Powerflex Poly Exhaust Hangers (they come too thick, cut-em in half for twice the supply!!) , Magnaflow 35171 Stainless Steel 3" Exhaust Tip and a smaller rear muffler in order to fit (Sounds Great and seems to perform better as well!!), New 4 Gauge starter to battery cables, Optima YellowTop Battery, I custom installed China 3M knockoff Carbon Fiber with heat-gun & exacto knife to Dash, inner-Mirror Covers, Seat Control bases, E-Brake sill, window control panels. I replaced Original Subframe as original was being held together with welds!! G4 Red Painted Calipers. Replaced original Headliner & A-Pillars (Still haven't figured out how to safely remove sunroof sliding door???), Philips HIR1/9011 (replaces stock 9005/HB3 High Beam) & HIR2/9012 (replaces stock 9006/HB4 low beam), Carbon Fiber license plate frames.
Stereo: Kenwood KDC X996 Head Unit (Great Sound Shaping, Time Management, Finicky Bluetooth!!)
Morel Hybrid Ovation II 4 2-Way 4" Component Front Speakers, Polk 6x9's, 2 x Soundstream 100W Amps (Front behind heat vent against firewall -fits perfect!! & Rear in trunk), JL 2x8" Subwoofer Custom Box with JL 500W Amp, ran 4 Gauge Power to trunk and 8 Gauge to front with fuse at battery thru bung hole in Driver Wheel well hugging the top and back of wheel well and drilled hole (Sealed with Liquid Nails) thru bottom of wheel well and another at bottom front corner of driver door under driver door sill (its hollow all the way thru-used clothes hanger to run both cables attached with Duct Tape thru wheel well to Driver Foot Sill Hole, rather than through bung over Clutch pedal as I ran the Zeitronix cables thru there ). Ran 4 Gauge under driver and passenger door foot sills to trunk. Attached Distribution Block (4 Gauge to 2 x 8 Gauge) with stay ties to antennae base. Ran 2x18ft RCA w/remote wire down passenger side door foot sills to Amps in trunk.
Best Expensive Mod: 4.05 Tranny w/LSD,SAS Swaybars, 19t Turbo, Engine Overhaul
Best Cheap Mod: Powerflex Front Control Arm Bushes and Tranny Mount, Drilling out Air Filter Box
Next Mods: New Aero Leather, Red Carpet, Refurbished Aero Wheels, Big Brake Kit, Up-rated Cam, valves and header!!
Seriously weird mishmash of bits in the above... 'listing'.
Shocks, Brakes ,even Tires are different front to back.. Why??.
Don't ride that thing in the Rain.
Model: Saab 9000 CDE 2.3 Turbo.
Year: 1995
Turbo: T25
Pistons: Stock
Rods: Stock
Crank: Stock
Block: Stock
Head Bolts: Stock
Head Gasket: Stock
Head Valves: Stock
Head work: None
Cams: Stock.
Downpipe: Stock
Exhaust: Maptun 2.5 inch. Sports cat.
Intake: BSR filter element.
Blow off Valve: Maptun recirculating
Intercooler: Stock
ECU tune: T5 Suite Stage 2.
MAP sensr: Stock.
Boost Control: Stock APC valve (T5)
Turbo Pressure: 17-18 psi.
Torque mount bushings: Proparts aftermarket .
Bottom mounts: ProParts .
Oil: Saab recommended
Fuel Pump: Stock.
Flywheel: Stock
Clutch: OEM.
Tranmission Gearset: Stock,.
Tranny mount: OEM.
Oil: Valvoline 10W-30 mineral oil.
Front Brake Discs: TRW aftermarket
Rear Brake: Pagid aftermarket.
Front Brake Calipers: Stock.
Suspension Shocks: OEM/Sachs.
Springs: Maptun Lowered springs (20mm drop from stock CSE)
Strut Brace Front: Maptun.
Sway bar front: stock.
Sway bar rear: stock.
Bushings: all aftermarket.
Wheels Brand: Stock
Bolt pattern: Stock
Wheel Size: 15.
Tires Brand: Good Year Efficient Grip Performance
Tires Size:195/65R15
Sent from my iPad using Tapatalk
21 - 35 of 35 Posts
