Ok, I've been trying to fix my 08 error code. I opened it up and realized I was missing the white stop lever all together. The yellow shaft seemed just fine. So, I pick up the newer reinforced stop lever from my dealer and get to work on it.
First I have trouble getting the stupid thing on. I have to spin my shaft just a little counter-clockwise to get the stop lever on. Finally, it goes on. Now, I'm trying to line up my step motor (i think that's what slides in the shaft) and screw it in place. It takes a little pushing to slide in the shaft and then.....pop
The little part of the yellow shaft that squeezes the stop lever poped off. Now, the step motor (could still be wrong) slides in WAY too easy and apparently spins without moving the shaft. Do the diagnostic and now I've got 3 problems instead of 1.
1 ----- 13
2 ----- 13
? ----- 08 (i think it's 1 again, could say 3)
So, I obviously need more help with this nightmare. On a good note, I did revive what I thought was a dead blower motor. One brush was wore pretty good and the other was looking good. Put a little electric contact cleaner and some very soft sanding, and back to life frankenstein.
As far as the problem I caused, have I totally screwed up now, or is there hope? Also, how did I cause two error 13 codes? Did I possibly do something wrong with the blower motor? I noticed two flaps and I moved them a little. Maybe shouldn't have done that?
Thanks as always
1 ----- 13
2 ----- 13
Thanks as always
