Hello my new friends. I purchased an 86' 900 (non turbo) about a month ago and am having difficulties diagnosing a couple problems which may or may not be related. Just for context, although I have spent a bit of time working on cars and have read through the Bentley service manual, I am still very much a novice/idiot so please forgive me if I have not considered something obvious or basic.
For starters I noticed the idle speed fluttering. Relatively small fluctuations for the most part on the dial. It probably goes around 100 rpm north and south of 750, but like once every 20 seconds or so, it seems to be bringing itself back from dying outright and today it actually did die completely when pulling up to a stoplight. It started right back up and was fine the rest of the short drive home but it was definitely disconcerting. Furthermore, occasionally, maybe once or twice a week, upon start up it will have extreme fluctuations in idle speed (Like 1000 rpm fluctuations) that cease once I start driving.
Another problem that I have noticed is a strong gasoline smell both inside the cabin while driving and outside and the smell is prolific enough to be present even many hours after driving. I have done a simple look over of the engine and fuel lines while the engine is running to try to spot a noticeable leaking of fuel and have been unable to find anything and am quite flummoxed as to where to start troubleshooting so that I may isolate/fix the problem.
Any advice/suggestions you can give on these issues will honestly and sincerely be very much appreciated.
-Sweet BabyTayTay
-Sweet BabyTayTay
