Hi,
I'm Sven from Germany and doing a T5 conversion on my '93 Lucas FPT right now. Hardware is done, Software and t7 valve mod also. Harness is nearly done, but i've a few questions.
First: i ripped of the old APC harness. But in the fuse box, there are two loose yellow/white cabels now, that are going to plug 152b and 152c to the main harness under the dashboard. I can't find, for what they are for.
Next: I want to integrate my A/C. I got a blue/white, a red/white and a grey/white cable from the AC Plug. Shall i plug them in to the Trionic ECU?
The thick grey/red and the red for the compressor is clear. Also i found a Video on YT, where someone tells, that you don't need the pressure switch with the circuit (red cable) in the water hose anymore. Is that true? Is there a function in the trionic ECU?
Ah and the BPC Valve Plug got the blue cable and usually the orange one. But my t5 harness only got the green and the blue one in it's plug. So i gorget the green one (Valve mode is done) and give the BPC Valve voltage. Wher should i take the voltage best from. Doing it with a fuse? Maybe from the main relais or the harness? I want to build a Fusebox. It should be +15, right?
And last: I want to integrate the EVAP System. I got the cables in the T5 Harness. Also the red/yellow cable from the EVAP Valve, that goes thru the firewall. And i got a grey/white one from the old Lucas Harness. Wich of them should i conect with what?
Maybe someone knows the Lucas Diagrams...
Sven
Sven
