1 - 7 of 7 Posts
Just bought a 97 900 se manual trans. and noticed after the engine and trans. warms up it is very difficult to get into 2nd. Its the only gear to have problems. I havent had time to replace the oil yet and wondering if that may help. Anyone else have this problem?
Discussion Starter · #2 ·
Also what would be the best gear oil for it as the owners manual says 10w30 motor oil??? And if a trans. additive would be recommended? Im a little stumped putting motor oil in a tranny
Your transmission came with two quarts of 10W-30 mineral oil and the newer transmissions came with synthetic oil. I change my transmission oil once a year because it's cheap insurance. When you drain the oil, pay close attention to how much it sparkles - that's caused by the worn synchronizers. Also, look for larger bits of metal... Ron
I've seen major improvements by switching to the synthetic fluid, then slowing exercising the syncros a little more each time you drive. That is, when you pull it to a gear, pause for a moment at the gate and let the synchro spin up, then flick it into gear. With the problem you have, I'd give it close to a second to spin up. Then work your way down to about 1/4 second over the next year.
I'm guessing you might be beyond just cleaning out the syncros with synthetic, but it's worth a shot.
Well finally got around to doing the switch, even ran an extra quart through to mostly get all the old oil out. It was a little sludgy but thankfully no metallic at all. 2nd gear is working great now. A little bit of a pain to get to but it definatly worth it. Thanks guys ;ol;
Excellente!
Keep doing what I suggested... pull it to "the gate", let the synchro spin up, then flick it into gear. Shift that way consistently and it should continue to improve.
1 - 7 of 7 Posts
