Hello again, I am still getting used to the unusual engine transmission on this car so bear with my terminology. I have a severe(half to a quart a day) trans oil leak at the very front of the transmission by the transmission mount. Any suggestions on where it may be coming from? Is there a seal that often fails?
Thanks in advance
Scott
Discussion Starter · #2 ·
update
based on digging a little deeper and looking at twinsaabs.com. The area that seems to be leaking is the transfer case housing. The part held on by a spring that kinda looks like a break caliper spring. Is there a seal in there that can be replaced?
The second to last picture on this page shows the leaking area with the cover removed.
http://www.twinsaabs.com/900_repair/clutchjob/step2.asp?nsteps=5
Thanks
Scott
