1999 Saab 9-5 SE 3.0 V6 with 4 speed Aisin auto transmission / Dexron fluid. 123,000 miles
Bought this car a little over 1,000 miles ago. Noticed that the shift from 3rd to 4th gear is a little hard (no slipping, though) so I think it's time for a transmission fluid change.
Previous owner passed away so service history is unknown. Transmission fluid level looks good but color looks gray / very dark red? But completely transparent like new fluid... just a gray shade instead of red? That's why I hesitate to call it black - it's clear and nothing like motor oil.
What do you guys recommend? I read many posts recommend multiple changes (2 or 3?) for a full flush. But is that too risky for a transmission this old with unknown service history? (my take). Or should I do just one change and add a bottle of Lucas transmission fix as a preventative measure? Or something else?
I guess I'm a bit nervous because on another 2001 9-5 with the same transmission, I did two flushes at 160k (no additives; fluid was normal then) and at 190k the transmission failed (fluid was very dark brown/black - not transparent at all). Just looking for the best way to avoid that if possible.
Thanks in advance.
Thanks in advance.
