OK, I've been out of the SAAB scene for about a year now but I have done this job 4 times now (owner of 5 SAABs). I refrained from really talking to much about how to do this as the local dealer charges ~$400 to do this and does the cutting method so often described on here (I charged less and did it faster). Not that the way I do it is novel in any way, shape, or form. Kind of makes me sick to call myself ASE Certified and get lumped into the catagory of these monkeys.
Anyway I figured this would be useful information for you guys doing this job.
Only had to do this job on the drivers side bushing on a '98 900, '99 9-3 lpt, '99 9-3 HOT, and '00 9-3 HOT. 2 of which were my personal cars.
Some of these steps will not be detailed as I assume you guys attempting this are more than capable of replacing an axle and we are just going a step further.
Step 1: jack up car, remove wheel, loosen spindle nut
Step 2: remove caliper, abs sensor, pop lower ball joint and tie rod, remove upper 3 nuts and take suspension assembly out (might not have to, but I did for more room, esspecially if you're using a BFH or anything other than an air hammer)
Step 3: use the axle removal tool and slide hammer to pop the axle out of the transmission
Step 4: you should see the bushing in question, insert the largest blind hole puller until the lip clears the bushing, tighten the tool, insert the 5 lb slide hammer (you can use the smaller slide hammer, the bigger is faster). bushing should be out in 2 minutes tops. PICS 1, 2, and 3
Step 5: start the new bushing in by lightly tapping it with the bushing driver tool. drive the new bushing in using a BFH or air hammer (only if you can come up with a decent adapter for the air hammer). drive the bushing flush. PICS 4, 5, and 6
Step 6: beverage of choice. PIC 7
Step 7: pop out and replace seal if needed (don't skimp, replace the seal)
Step 8: reassemble your front end
Tools needed other than a normal socket set:
BFH - Big Friggin' Hammer
27033 - 5lb slide hammer (Autozone Loan-A-Tool)
27058 - axle puller attachment (Autozone Loan-A-Tool)
27128 - blind hole puller set (Autozone Loan-A-Tool)
27137 - bushing/race/seal driver kit (Autozone Loan-A-Tool)
