interested to know
Hi all, great forum by the way
Just wondering, I have read many times within the forum that the consensus appears to be that the 90+ gearboxes are stronger ?
I know that the 90+ gearboxes run larger pinions and have different pitched gears, the lay shaft has the oil feed slot, etc etc .... but in my profession of rebuilding the 5 speeds 95% of the gearboxes with collapsed pinion bearings or broken pinions or broken main clusters and other gears etc ... were the later 90+ gearboxes. Seldomly did we see the earlier 86-90 gearboxes with problems other than aged wear?
Where is the perception that 90+ gearboxes are stronger coming from .... maybe sometimes size doesnt matter
If anyone has any info regarding improved strenth in the later gearboxes some links would be appreciated as I am interested on reading up on it
Thanks
