As some of you will recall, I completely replaced the engine oil cooler lines and the oil filter housing to stop a fairly serious loss of oil from those components a short while back.
I have been carefully monitoring the engine bay to see if I figure out where other oil leaks are occuring but so far nothing obvious. I originally suspected the crank pulley seal but there's no fresh oil showing up around that area with the exception of a small amount that appears to be coming from the timing cover seal.
What's making me concerned is that the oil level is still going down noticably over the course of a week or so. Nothing like it was before I did the oil filter housing and cooler lines (it was going down a litre over 1 to 2 days!), but I'm topping up with 1/2+ litre weekly at present.
A few other possible oil leak sources I can think of are:
- turbo. It's oil-cooled only. Like the crank pulley, I can't see any fresh oil leak evidence and I renewed the feed and drain pipe seals some time back.
- engine block itself. I haven't done a compression test since the engine runs well, but it's a very old engine and the rings, etc. could be very worn.
- front oil seal. This one would require full engine/trans removal as with an auto trans that seal is not accessible until the engine and trans are separated.
THe burnt smell I noticed from the ATF may be a symptom of the last possibility, and being oil mixing with oil, ATF and oil probably don't show the same obvious indications that occur when coolant gets into oil.
I know for certain that the engine oil cooler does not leak, nor do the new cooler hoses, or the filter housing, or the oil pressure sender mounting.
I have been using a slightly thicker synth oil (Shell HX7) to partly address the oil loss since I re-did the cooler and filter housing.
Short of pulling engine to actually get at the front seal, what else can I do in order to identify where the oil loss is occuring from?
I might do a compression test on the engine next time I get the chance just for the sake of it and see what the results are.
Is it possible that the HG or something related to that could be causing the oil leak? (noting that there is no evidence at all of oil contaminating the coolant - it's nice and green and there's no residue or 'scum' line around the inside of the coolant tank). Likewise the oil appears to be clear of any coolant.
Comp test should hopefully give some results to refer against other observations.
Craig.
Craig.
