1 - 2 of 2 Posts
Guys, I can't get the system into learn mode.
2009 9-7x, I follow the procedure in the manual and no double chirp. No chirp at all. I verified parking brake switch works fine. And horn does work. The TPMS system works fine otherwise and I haven't changed any sensors. I just need to relearn because I found out some bozo at the tire place rotated the wheels without being asked to.
The only questionable issue is that the procedure calls for switching betweeen OFF and park lights. The car doesn't have a headlight OFF position. The default position is AUTO like other GM cars of the period. But on a different car I was able to get into learn just fine by switching 4 times between AUTO and parking lights. So it seems unlikely this has to do with it.
Any ideas?
1 - 2 of 2 Posts
