Greetings all,
my error warning is on the SID but all pressures verified correct. Is the spare monitored; and if so would its low pressure show up as one of the actual wheels? Is there another way to reset it because Sport mode is denied to me right now...?
regards and TIA!
s
Spare is not equipped with pressure sensor.
You have bad sensor if pressure is correct in all 4 wheels.
Thanks gents. I did see in the owner’s manual that the spare is not monitored. Strangely after nearly an hours total cumulative drive time since i got the warning and checked the pressures the warning went out.
in a few days I’ll be swapping to winter wheels/tires and this is the end of these summer tires due to wear, so i will have the sensors dealt with when i get new tires.
regards
s
