I'm planning on changing my ATF fluid in the holidays. (00 9-3)
My haynes manual and the WIS refer to a 'special tool' for undoing the drain plug/ access point in the auto transmission. Is this just a spanner and potentially allen/hex/torx key - or is there something else I'm missing? When I've read a break down for a 9-5 for example - everyone just talks about a spanner eg 24mm and a tight fit - so a closed ring spanner is preferred.
If there really is a special tool for the 9-3 trans - and is it common enough to purchase at a normal auto parts store etc?
and the critical info .. what is it technically called?
