Saaboheme said:
Or it might need a bleeding. How old is your brake fluid and when was it last done? Where in relation to the floor does your clutch engage and disengage? Since you are describing the two shifts where the car is stationary (1st and reverse) this could be a linkage issue. When you have difficulty, can you run through some other gears and then get the one you want?
Not sure how old the break fluid is, the car was purchased back in June this year with 98k(km) on it, and according to the dealership was serviced before the sale. In terms of approximately where the clutch engages/disengages, hard to desribe, but it disengages when the pedal is fully pressed down, and engages not too soon after. Its hard to know if the previous owner changed the clutch at all, but I personally believe its fairly solid and still has some milage on it.
To answer your last question, seems like sometimes when 1st is being difficult, the other gears (when stationary) are somewhat difficult as well to shift in and out of (I usually try 2nd when it does that).
Appretiate the help as always, I'll search around the forum for linkage issues. Cheers
