1 - 2 of 2 Posts
Hi There,
my 2005, Saab 93- Turbo - Convertible has a lot of error codes related to throttle probably its throttle body.
I got error codes:
P0223 throttle pedal
P0638 position sensor
P1682 throttle actuator / control range
and a non related code P1682 , a voltage +15, main relay
Someone recognizes the main issue to start a repair with?
The car runs slow on low gears. could this be turbo related too?
Any suggestions?
Rgrds
Cee
Check the grey connectors under the battery for any signs of the corrosion .. if not, then we start diagnosing with u ..
What scan tool do u have ?
1 - 2 of 2 Posts
