1 - 12 of 12 Posts
Well for about the past two weeks I have had trouble starting my car on the first try. I can put the key in and try to start and it may take 10 seconds before the car starts. What I have started to do is give it a short crank and then crank it again and it starts right up. My car has a new battery, fuel pump and filter and I just completed the 60K mile maintenance abour a month ago. The only thing I can think of is the injectors need cleaning or the throttle body. It runs perfectly fine after it starts up, but my fuel mileage sucks. I'm currently getting @ 18mpg in all city driving. Are there any special precautions I should look for when cleaning the throttle body and does an additive like the concentrated Techron really work on injectors?
Nothing special about cleaning the throttle body, just make sure to use a throttle body cleaning spray as opposed to a carburetor cleaning spray.
You can push and open the butterfly valve without the engine running to clean inside.
My guess is: Since you just had the 60k mile service, it entails changing the spark plugs. If you're having starting issues the tech. most likely incorretly gapped the spark plugs, I would check there first.
Plugs were double-checked and they were the factory plugs as I purchased them from the parts department and he told me they come gapped. I had him check them in front of me and they were correct. The strange part is it cranks up in the morning and there is a shutter for a couple of seconds and it idles smoothly. If I turn the car off and come back to it in say 30 minutes it will also crank fairly easily. If I let it sit for a few hours I then have the problem starting again. This did happen before the maintenance a couple of times, but I thought it was due to the new fuel pump and having enough gas run through it.
Sounds like a fuel leak allowing air into the fuel system when left for a period of time or a malfunctioning fuel return valve that is allowing the fuel to drain back into the tank.
Either is possible following recent work on the fuel system/pump.
It was indeed the throttle body. My car has just over 61000 miles on it just in case any of you want to take a look at yours. There was a nice amount of deposit in there and I clean it out until my rags came out squeaky clean. I fired it up yesterday afternoon and then went back out last night and everything was beautiful. This morning it fired up also without a stumble. Thanks for the help.
do you have a video on youtube??
I just watched a video on youtube of a 95 aero wagon having the EXACT same problem but i just checked again and the person just deleted the video :eek:
patcom said:
did your gas milage increased after cleaning out the throttle body?
I can't really tell you. I haven't driven the car since I did the cleaning. I'll let you know probably this weekend. I decided to drop the car off for a custom exhaust.
how did you do that?
easy to do?
where is that throttle body?
how does it come apart?
i would be very much obliged and would like to give it a try myself...
bump.. curious if this fixed your issue OR if its just because we are starting to finally get freezing weather in the Southeast now? My car has 3 times maybe not started on the first crank, only on mornings when its less than 34 though.
I picked the car up yesterday and drove to a couple of places that are out of the way. Throttle response is much better and the car did start on the first try, but it did take a little longer than expected. For fuel mileage I reset the SID, but on a full highway trip of about 50 miles I was only able to get @ 24.6mpg, this is nowhere close to what I used to get of around 28mpg. I'm at work now, but I have to leave out shortly and I will see if the car starts on the first try again. I did some more reading on possible reasons for hard starts and looks like I may need a new fuel pressure regulator which is like 30 bucks and appears to be fairly easy to install.
On a side note, I test drove an 03 9-5 Aero yesterday and I think I'm going to fix all the problems with my car and sell it and buy a 9-5. The sound of that engine was beautiful, it sounds like a large V-6 is under the hood. What really sucks is I just put a new muffler on and bought parts for a brake swap on my car. :evil: I can never make up my mind.
1 - 12 of 12 Posts
