I was bleeding my rear brakes with a clear tube and watching the bubbles come out... after a while I think I was convinced that on one side, the air was coming in around the threads and heading out the bleeder with the fluid flow. If I moved the tubing around to make the screw move up and down in the threads, more air would definitely come out the tube. I think they're bled, but I'd be more comfortable if I could see it run clean. I only had the bleeder loosened about 1/8 turn, but there was still play at that point.
What can be used that resists brake fluid and will stay soft enough so I can bleed a few times, then break it free next time I need to flush the lines?
