I know there a lot of you out there who have had the same problem with the third brake light leaking, so I thought I would post this photo with a question.
Thanks to everyone's help here, the process of removing the brake light is very easy, the inner trim piece can be removed using just your fingers. When I removed the 10mm screws that hold the brake light in place, the clip on the right just crumbled. I think the clip was already cracked apart before I removed its clipped in screw. Is the leak a result of the rubber strip around this thing getting old, or is the leaking caused by the cracked clip, or both? How are you guys dealing with this problem, eEuro parts wants $140 for the replacement brake light assembly.
