I decided to do some maintanence on the Viggen as the water pump was leaking and making a bit of noise. So far I am replacing the following:
*Water pump and water neck o-rings
*Alternator (works fine but has 110,000)
*Belt tensioner
*Idler pulley
*Serpentine belt
*Bead blasting the alternator bracket and power
steering pump bracket
Debating whether to drop the oil pan and check the screen as the car has had a diet of synthetic oil.
Also wondering if I should replace the upper and lower radiator hoses.
Anything else you can think of ???
*Belt tensioner
*Idler pulley
*Serpentine belt
