I have recently been contacted by many Saab owners on how to install a aftermarket radio system by cheating the fibre optic bus system. See the thread posted last year:- http://www.saabcentral.com/forums/showthread.php?t=44858&highlight=fiberoptic.
So I thought is would be better if I explained on this site so everyone can know. As far as I know this has never been documented before and I have done many digital electronic tests on the cars system to make sure no faults occur. Its been about 9 months since I installed the system and have had no problems at all.
As I done my installion last year and only took few pictures (that are on my web site) I couldn’t take new pictures of the optic cables worked on to show each step of the way as its too much hassle for me to take out my system now.
Your Saab’s original system will still work along side your aftermarket one. Basically, you are just bypassing and taking the CD unit out so you can get a Din size space in your dashboard. As you may know the car does not start if you unplug any part of the Audio system because of the optic bus system. To do this you can either make a optic cable loop-back cable or just modify some existing connectors. Both process are completely reversible as no permanent changes are made. http://www.sevani.com/Projects/SaabSoundInstall/photos/photo_1.html
Before you start make sure the radio system and your ignition is off.
The modifying existing connectors way: -
1-Remove ACC/MCC unit and then the EHU with the CD.
See link- http://members.iinet.net.au/%7Emmo/HeadUnit/headunit.htm
2-With all the cables removed from the EHU and CD unit take the CD out.
3-Look at the Plug that came out from the EHU from the front end and you should see two optic cables on the side. One of the optic cable should randomly pulse a red light. If not open and close the doors. This will re-activate the Bus System. That optic cable is your bus feed in.
4-The one next to that optic cable needs to be taken out from the casing it is in. This is a extrermfully delicate process. A plastic lug is pulled out slightly to release the optic cable plug within the main plug. Then a blue coloured tab is pushed out completely and then another lug is pulled up to release the individual cable. See Pic A
link- http://www.sevani.com/Projects/SaabSoundInstall/photos/photo_2.html
5-The optic cable taken out needs to be free as possible. Carefully undo all the insulation tape around that cable as possable. It should lead to the CD bus connector.
6-On the CD plug there’s the optic cables and a two Power wires. The two wires are in a separate plug that is detached from the main plug leaving the optic cables only. Isolate the CD power cables with tape.
7-The optic cable next to the freed one is taken out like in step 4. This should now give you a completely removed fibre optic cable with the CD plug on the end.
See Pic B
Link- http://www.sevani.com/Projects/SaabSoundInstall/photos/photo_3.html
8-The optic cable freed from the CD unit is then feed back to the EHU plug and inserted in place of the one taken out before. Thus completing the Bus system.
9-Also on the EHU the plug contains the speaker cables, which you may need to wire upon installing your Aftermarket system. Please note that it only covers the back and front two side speakers. The amp under the seat usually powers the rest.
See link- http://www.sevani.com/projects/SaabSoundInstall/index.html
10-As Saab’s audible warning sounds are through the front speakers a trick for keeping this feature is that to rewire the centre speaker from the Amp under the seat to one of the front channels on the EHU socket.
11-Plug the EHU and ACC/MCC units back carefully tiding up the optic cable with insulation tape. Also, be very carefully so no optic cables are stretched or bent.
12-Insert you ignition key and power on the Radio. Select the CD disc as your source and you should get a message “No disc available”. Congratulations, you are now ready to fit you Aftermarket system. The car should start with no problem and all your other sources on the system should work fine. See Pic C
Link- http://www.sevani.com/Projects/SaabSoundInstall/photos/photo_4.html
Hope this has helped you Saab 93ss Owners out there. Keep an eye on my website as I have many crazy things planned for my Saab.:lol:
Raj
See Pic B
Raj
