I've been noticing a loud vibration coming from inside the center console under the radio. I eventually traced it to behind the seat heaters/temp sensor panel. Removing it, I found the vibration noice is coming from the fan behind the temperature sensor, which I assume is pulling air in over it. No matter which way I try and move it, the vibration won't get better. Is this a part I'm just going to have to replace to get rid of the sound, or has someone come across this before and have a solution? Thanks! And I hope all you other Americans are having a great Thanksgiving weekend!
