1 - 13 of 13 Posts
· Registered
Quick rundown-
Car- 2003 9-5 Aero
Equipment- Mongoose Pro GM II
Software- Tech2Win, Techline Connect, Tech2Win Emulator, 2 different SAAB NAO bin files/ profiles on tech 2.
Repair- Replace TWICE Module and program it to the vehicle.
Tech2Win said "CANdi detected- please remove" or something of the sort, so after disabling CANdi, it gets through to the next page but then says,
"No BUS Systems can be contacted- No Communication with DICE"
and won't let me go any further.
What am I missing?
(Only current code is that the twice module vin does not match the vehicle)
Any ideas would be helpful, this is a customer vehicle and we were hoping to have it done days ago.
Thank you!
· Registered
2003 9-5 do not use CANdi, so remove it.
Check wire between DICE pin 28 and OBD port pin 7.
Check also all fuses in dash fuse box.
· Registered
Have you double checked wire between DICE pin 28 and OBD port pin 7?
Try to change MY at TECH2 selection.
· Registered
Discussion Starter · #10 ·
I figured out that it isn't just the dice module, it won't communicate with any of the modules under "body".
Everything works great for other GM vehicles.
ACDelco TDS support checked everything and said it was good from remote laptop control then said to call mongoose support.
Mongoose support said to call AC Delco back because everything looks good.
There are no blown fuses. The car appears to have no problems other than the TWICE module isn't programmed to the vehicle.
I've dumped $1000+ into this repair between parts, software, hardware, etc.
I'm probably just going to tell the customer that there's nothing I can do anymore and tell them to go to the SAAB service center and sell what I can that I bought for this repair online so I don't throw all of this down the drain.
· Registered
All electronic modules communicates thru DICE. So if DICE is not responding, none will respond to TECH.
1 - 13 of 13 Posts
