After being burned on a GM MDI which was promised to totally and definitely work with my SAAB, only to find out that Tech2Win couldn't successfully communicate with anything, I decided to sit down, figure out why, and fix it.
And now, I've done it! No longer will you be plagued by "I-Bus Missing" error messages stopping basically all communication with your 2003+ 9-3. To make a long story short, some bug in Tech2Win or the SAAB Tech 2 software itself causes all communication to be done in a certain mode without actually switching to that mode. All the CAN messages then go out to the car with the wrong header, so the car immediately ignores everything, and the Tech 2 concludes that the car must not be there. I have prepared a version with the issue fixed. Download it and read the README.txt inside the archive to get it started.
SOME IMPORTANT NOTES (cliff's notes version; full version is in the README)
Happy Tech2Win-ning!
- I have tested this version of Tech2Win on 32-bit Windows XP and Windows 7 and it works great on both. It also works great even in a virtual machine.
- I have only tested with my clone GM MDI 1. You should be able to use any other VCI that is compatible with Tech2Win, i.e. those that support D-PDU API/ISO 22900. If you need to purchase or set up a VCI, there is some advice in the README.
- There's some chance my fix will break communication with other SAABs and/or other vehicles that Tech2Win supports. If you run into issues there, try using the non-fixed version (which I have also included in the archive), and let me know. I only have 2003+ 9-3s so I can't test this case.
- I've tested and verified correct operation of every function I can think of on my 2003 and 2007 9-3s, including reading and clearing DTCs, reading data, performing activations, bus testing, getting security access, changing personalization settings, adding and removing modules, and adding keys. There may be other functions that do not work.
- There may also be functions that unexpectedly destroy your car, computer, VCI, life, limb, etc. I can't be held responsible in this case!
- Please check this thread for any updates as I have difficulty editing the post.
