1 - 20 of 28 Posts
Hello,
I need your help i have no communication between my tech 2 and tis 2000.
What's the problem? Bad wire?
Can be.
Do you have serial port in your computer or do you use serial/usb dongle?
Yes i have serial port
I dont have serial/usb at this Time only serial port come with the tech2
Did you tested serial port?
Have you tried another serial port (select from TIS)?
If yes to both, you have bad wire.
Have you tried with another cable?
Discussion Starter #11
They test 2 others câble but not succesfully..
I have Laptop Dell D610 run with xp and already have tis2000 install on it.
Tech 2 work great with car (clone tech2)
Any Idea?
Discussion Starter #13
Have test 3 cable with no result..
Im wait for the last cable to arrive it's a key spain (usa-19hs) model.
As I told you only few of them works, you have to try another cable(s).
Discussion Starter #15
But the câble (spain usa-19hs) it suppose to work?
Im waiting for it today and test
Discussion Starter #16
what is the best cable I should take to make sure it works. I don't want to try 10 cable ...
No, because cables and TECH2 may vary.
Remember that I use original TECH2.
Only what I can be 100% sure is die.
Discussion Starter #20
I received my wire keyspan usa19h without success ...
I have to do something not correct I don't understand ..
I try all the com..
1 - 20 of 28 Posts
