1 - 17 of 17 Posts
Hi All!
Three days straight, a couple of 5am finishes and little progress to show for it. To say I'm frustrated is an understatement!!
My (clone) Tech2 does everything (read/clear codes, makes adjustments on all modules, etc) but allow me to program anything. I have full access and rights through both TIS2000 and GlobalTIS via an older Dell-Windows XP (fresh install) laptop with straight RS232 connection. I have tried everything recommended, including, but not limited to:
  • Re-flashing the Tech2, trying different software revisions along the way
  • Re-flashing the card, trying different software revisions along the way
  • Changing the slot the card is in
  • Remote, Pass-thru, etc operation via the Tech 2 and through both TIS2000 and GlobalTIS
  • Changing COM ports, although I needn't (a sign of just how desperate I've become)
  • Removing the battery (GM recommendation) to drain all power from the car and reset
  • Then, trying it on a different (9400) car
The list really does go on, but I won't bore you with it.
What I haven't tried:
  • Performing the operation on a (9440) with the Candi (just to see if that makes any difference)
  • A different OBD lead; as I only have the one that came with the unit
  • Putting the Tech 2 in the freezer for a few hours
These are the two error messages I receive when simply attempting to read the VIN/ECU information so as to then gain security access:
273680
273681
I keep thinking I've missed something simple, but have been over it so many times I'm at a loss!
Any ideas would be greatly appreciated!!
What car and module are you trying to program?
The V44 software will let you do OG9-3 and 9-5 up to at least 2003. Of course there are only a few modules that can be SPSed in the 9-5: ECU, TCU, ACC.
V44.000 do not let you do any 9-3 or 9-5.
44.000 in for 900 and 9000 ONLY.
You have bad cable or wrong port selected in PC.
Mimmi, that is incorrect. I have done SPS on my 2003 9-5 using V44. This was only ACC, I have not tried ECU.
See Technical Bulletin 02-11-248.
273690
....And I used V44 after having no luck with V148. Apparently there is a version of V148 that does allow SPS programming. We have a club member who does have that card, but due to lockdown we haven't had a chance to investigate/update.
Confusingly, both versions of software are 148.00. Not sure how to tell them apart, or whether there is a bad copy out there.
Discussion Starter #6
Hi Mimmi, EdT,
Thanks for your replies.
The car is a 2000 9-3 and I will be looking to program a spare ECU for it. I will also need to program spare keys for other 9-3 (9440) models for family.
When you say a bad cable, do you mean the network cable or the OBD cable? As I have swapped several network cables in-out with no difference. The OBD cable I too can't be 100% sure, as I only have the one. However, for all other functions, it has worked perfectly.
Thanks again EdT,
I take it from that, that I'll need this V44.
I can't believe that after the hours of reading over the last few days, that this is the first I have heard of it.
Hopefully it works properly for you!
It's been a year since I tried to do SPS, so I forget what errors I was getting with the 148 card.
Discussion Starter #10
Thanks EDT.
44 didn’t work (same error) so I’m working my way back through them in case I missed one. That said, I can’t see why I’d have to jump between revisions based on the model I’m working on. No-one’s mentioned it (that I’ve read) and it doesn’t make sense that GM would update the software without a degree of backward compatibility.
The fact I can communicate with all the cars I’ve worked on but not pull a VIN to the Tech2 doesn’t make sense to me.
I’ll try the next one in the morning, but I feel I’m just repeating what I’ve already tried.
Thanks again!
V44.000 do not work. V44.000 do not even have 9-3 or 9-5 to select.
You need to use 148.000.
You have bad cable between TECH2 and PC or incorrect port selected.
Discussion Starter #12
Hi Mimmi,
Thanks for that.
So, I worked my way back through to 148.000 again. I have also completed another round of the Tech2 self tests, which passed. I then took out and apart the VCI and (with a multimeter) checked all the connections from the PCB to every pin along the connection path through to the end adapter, which were all good also.
Again, what I don't understand is being able to program those modules in a 1999 (9400) 9-3 that don't require security access, but when I request the VIN to potentially program a new ECU, it fails.
If you program modules, you do not need to use serial port.
If you request VIN to program new ECU, you need serial port to PC.
So, I say that you have either bad serial cable, bad/invalid serial/usb dongle or wrong port selected in PC.
TECH2 is extremely sensitive to serial/usb dongle
Discussion Starter #14
Thanks again Mimmi.
I understand, however, I think there is some confusion as to which step in the process my Tech 2 is failing, as it is unrelated to the Tech2-to-Compter/Laptop connection.
I don't have that computer in front of me at the moment to screenshot the steps, but will post again over the weekend.
I appreciate your help.
So:
  • I was incorrect, it was V43.000 that I was referencing
  • The problem I encounter with V148 is that the Tech II locks up immediately when selecting SPS programming; the unit has to be turned off and on to restart it
  • V43.00 does indeed do SPS programming of 2003 9-5 (see pictures below)
  • V43.000 has only selection for Saab 9-3 and Saab 9-5 from 1998 to 2002 if SPS programming option is selected (so no luck for NG900 owners)
  • For 2003 9-5, select 2002 and continue, no problem
  • V43.000 does not work with NG9-3, probably does not recognize CANdi
  • I did not follow through on the SPS, but believe me, it works, I SPSed the ACC, and when I get around to checking the spare ECU I have, I will SPS that
273769
273770
273771
Try using v.146 on the Tech2 (get it from GlobalTIS). I ran into similar problems doing an SPS ECU reflash on a 9-3SS with v.148. I posted about it a few weeks.ago.
Discussion Starter #17
Okay, so a bit of a delay in getting back to this with my work kicking back in.
Big thanks EdT for taking the time to verify that for me. It was a massive help to be able to tick that one off the list!
Basically, I think I've worked it out having clarified a couple of unknowns that still existed despite all my testing to date.
  1. I packed up the Tech2 and waited till I had access to a 9440 9-3 that I've been working on. Plugged it in, read and loaded the VIN, no problem. That had me confident it wasn't a hardware issue.
  2. I, like a few others, didn't have the security access icon on the TIS2000 desktop showing. However, I had it on my GlobalTIS desktop and could access that. So, I re-installed TIS2000 and voila, there it was. Don't ask me why; I followed the same walk-thru as before, I simply got a different outcome. After the amount of time I'd spent on this, I simply took it and moved on.
I have since completed programming on the 9440 9-3 and as soon as I have the time available, I will roll back to v.146 and fingers-crossed, everything will work similarly on the 9400 and that'll be the end of it.
I don't think I wanted to know that much about the Tech2 hardware (dismantling and testing VCI modules, pin-outs etc) but knowledge is power, right??
Thank you all again for your help!! 👍
1 - 17 of 17 Posts
