1 - 16 of 16 Posts
· Registered
Hello,
Vehicle: 04 saab 9-3 Aero
I was searching online trying to figure out what this tech 2 code is and havent had any luck.
" error!
No comm or lost comm with ECU:
CIM
Column integration module
addrem.c, line 2420
Press <EXIT> to return "
I should mention that I am using a vxc nano.
It gives me the same code no matter what module I try to add or remove.
· Registered
Select model year.
Select model.
Select all.
Select read all DTCs.
Basic function.
Sorry for the delayed response!
I tried doing what you mentioned and this is what I got.
"I-BUS missing. Tech 2 cannot contact CIM via DLC pin 1.
Flash Hi beam to check bus. If OK, check pin 1 of DLC and its wire to CIM. If HI beam does not work, reason is a total I-BUS failure or no power supply to CIM. I-bus activity can be verified using test lamp 8611857 between DLC pins 1 and 4.
See fault tracing in WIS Section 3: BUS and diagnostics communication. "
I tried flashing my high beams then got this random switching where in the trunk it sounded like something switched on and off really quickly and it kept happening.
· Registered
Car battery condition?
It's funny you mention this, yesterday as I got off my bus and tried to start my car it wouldn't start. I replaced the car battery 2 weeks earlier. I checked the alternator to see if it is charging the battery all checked out well. I got a little bit of a charge on the battery and when I put the key in the ignition I could not turn it and the dash displayed " Steering lock malfunct. Stop the car. Contact a Saab dealership." I suspect it is the key switch having issues. If I was to buy a key switch online do I need to do some kind of programming for it?
1 - 16 of 16 Posts
