Maybe you can direct me.
> I tried to replace my license plate bulbs with LEDs. The left one went
> fine, but the right one pushed through, knocking the connector off.
> I took the trunk panel off (breaking most of the plastic push clips (2 piece)
> and need to replace them.
> Hard to imagine but, the connector is hidden behind the metal stamping.
> No way to get the connector back in place. I would literally need to cut a small door way.
> Any idea where to look for replacement clips? Must be new as I think they were designed as single use only. Mine are light grey
Try ebay looking for plastic rivets. There are hundreds of types so you'll need to know the hole size if it doesn't state its Saab compatible. Otherwise a dealer as they may not be as expensive as you think, I just bought some plastic nuts from a dealer at 19p each.
You didn't need to remove the liner; all you have to do is remove the outer trunk handle the light is attached to that; that's why you can't get to it from the inside. The handle should be held on with 4 bolts; part # for the rivits is 92152036, eeuroparts.com
When removing, push the center in about an 1/8" and pull the whole thing out; to install remove the rivet install the holder then insert the rivet.
