I'm stuck in the good ol' US of A and can't lay my hands on a manual for the 9-5. I saw the post for getting the UK Haynes book, but need help sooner. To wit, how much stuff do I need to remove to get good access to the T-stat bolt. The space is packed! Any sites anyone can recomment besides this one?
I've got a 2000 9-5 2.3l.
Many thanks
I'm told it helps to move/remove the delivery pipe. I don't really know, about to try this myself. :confused:
Thermostat 6cyl
1. Open expansion cap to release pressure
2. Raise the car
3. Remove lower front engine cover
4. Drain coolant
5. Lower the car
6. Remove upper engine cover
7. Remove Upper intake manifold
8. Remove middle intake manifold
9. Remove lower intake manifold
10.Remove mass air flow sensor and hose
11.Detatch turbo intake pipe and move towards intercooler
12.Detach Turbo bypass pipe
13.Detach connection to the crankcase breather pipe
14.Remove dipstick and pipe going to thermostat
15.Remove thermostat and housing
16. Clean all surfaces
17. Use a little non acidic grease to the thermostat's o ring
18. Reassemble
19. Then there is a whole chunk on venting and filling the cooling system
20. Give up readining this on go to a mechanic ;)
Erm.......................good luck :eek:
Thanks for the replies. Got the job done with a bit of experimenting and lots of patience. Very different animal than the 6 cyl. No specialty tools required, but a few might make it easier.
Thanks again.
Thanks again.
So why did I post the instructions for the V6 :confused: Time for my tablets :(
Well done Craig :p
