So, I am starting on a redesign for the rear ARB mounts. The overall geometry makes this a pain to cut on 2 passes so I am still concerned the cost may be too high for a solid CNC piece. This might have to go to a local fabricator I know for 18GA sheet work. He can make anything look nice.
Wood Office ruler Input device Peripheral Office supplies
Those sound great, these are either costly to replace or not available. The main real issue is the bushing, and to a lesser extent bigger support plate inside the car.
There are several innovative fixes involving stainless pipe and poly bushings that sort this for modest cost and a bit of work, I can find this approach and put it up here if there is any interest.
My friend is backlogged so no local product. My current solid design can be cut for under 60 a piece out of 6061. I have a plate design already and can get them laser cut.
The bushing that will fit this can be OE or preferably Energy Suspension's greasable poly. I have a 17mm sample bushing for the kit prototype but you can get 19, 20, etc.
New 300x300 3D printer set up and printing a prototype out of carbon fiber PLA. Got lots of space now to prototype big parts. The old Monoprice Select Plus 200x200 still does a good job after 8 years but this one has a larger bed, faster and more precise extrusion, a sprint plate which requires no bed prep and auto-levelling. The extrusion head is mag-mounted too for easy servicing.
Wood Automotive exterior Technology Machine Metal
