Thanks to AeroErn for posting his thread to make me attempt this. Let me first say that I am in NO WAY mechanically savy when it comes to cars. I don't even know how to change oil properly.
What drove me to fix the annoying sunroof plastic rattle/creaking/cracking noises was seeing those pictures. I was scared ****less while doing it to my MY 07 SS. I was so scared I'd break something or I'd mess something up, but thankfully I didn't.
It was VERY HARD to remove the center holding cap which holds the sunroof frame in place. When I pulled hard on it the whole frame popped out of the back and I had to wiggle it out from the frame. I even cut myself on the plastic in the process (see, I'm a klutz!).
I bought some electrical tape at ACE Hardware after class this morning and went right to work when I got home from school. Once the frame was off I noticed that the headliner was all shabby on the ends. I didn't tape the headliner at all as AeroErn suggested. I really didn't see the need as that didn't seem to be causing the noises.
I put two layers of tape on each side of the metal frame surrounding the sunroof as to make sure to dampen any creaks from coming back. I found it best to cut the tape into smaller pieces when taping the corners and to do 12" strips when doing the longer pieces of metal. I think I was a little too liberal with the tape in the end.
Anyhow, once all the metal was taped up I proceeded to place the frame back in place. THIS WAS THE HARDEST PART. It won't fit in at all if you just place it back in. You have to squeeze one corner (front first) in at a time. Make sure the headliner goes up into the frame. Step outside the card and work from the top of the sunroof looking into the car and guide the frame back over the metal strips and into place. I used the palms of my hand to really pound the frame back into place. IT'S REALLY STUBBORN TO GO BACK IN!!! You have to use a lot of force to pound it back into place so it's very snug. The rest is pretty self evident. Pop the center cap back in (with some force) and you're all set.
THE RIDE IS SOOO QUIET NOW. It's like a TOTALLY different car. I no longer cringe when going over bumps in the pavement. It's silent!!! This is amazing!!! I encourage all those who haven't done this to do it ASAP. You won't regret it. TRUST ME :]
Here's some pics...
Here's some pics...
