In the most recent task I got the sunroof working but I found broken nylon bushings on each side of the frame where the bracket (I call it a lock) is that secures the glass frame when "closed". Are those D pieces of plastic supposed to go on the ear sticking out of the bracket? The sunroof refuses to seat properly in "closed" and hangs on retract unless I move it back and forth a few times with the switch.
271056
Those plastic mounts are called "sliding plane" and are available in Sweden still.
RH 6975262
LH 6975270
Too bad I can't just order the nylon bushing. That slides along the bottom glide so no wonder it's loose. Those are only about $20 each + shipping from Sweden so I'll just order new ones.
271073
