1 - 20 of 30 Posts
We're off schedule again.. this time due to me attending Carlisle.
Ill try and get this back on track
The rules are posted in the sticky in the main section for SOTM Submission & Voting
(here's the link just in case; SOTM, Rules and other need to knows.)
Open for entrants!!!! Will close on the 5th
follow this template
***EXAMPLE***
The Silver Sled (1988 900 Aero)
Specifications
Engine
Brand new Saab B202 2.0 Litre 16 valve crate engine (installed November 2010)
Rebuilt Bosch distributor
Stock Bosch electronic ignition
SPG9 AID (Advance Ignition Diaphragm) with timing at 20˚BTDC
Bougnicord spark plug leads
NGK BCP7EV plugs
Aquamist 1S water Injection using 0.9mm injector
Aquamist DDD (digital dash display) for water injection output
Crank case ventilation catch-can
Exhaust
2.5 inch from cat converter back with hi-flow racing cat
4 inch chrome semi-oval tip
Hi-flow dynomax stainless steel muffler and rear resonator
3 inch JSP stainless steel split down pipe off turbo to cat
Turbo
Mitsubishi TE-05 16G: with 16G compressor wheel with 10˚ clipped vanes, upgraded thrust and is rated as a 300HP turbo
Wastegate running 7psi base boost
Stage 2.5 SPG9 APC running to 18psi boost
Jak Stoll Performance Talon high-flow side mount intercooler
8 inch Davies Craig thermo pull fan mounted on reverse side of intercooler with manual switch inside cabin
Saab C900 1990+ aluminium turbo intercooler ducts
Stratmosphere Forge bypass valve
K&N filtercharger
Plastic intercooler top air dam
Fuel System
Bosch 3.0 BAR fuel pressure regulator
Trionic 5 34lb injectors
Jak Stoll Performance Stage 2 ECU chip
Fuel pressure gauge situated in-line on fuel rail
Suspension
Stock Saab Aero springs and shocks
Stock Saab Aero road handling kit including front and rear sway bars
Polyair inflatable air bags inside rear springs
Wheels & Tyres
16" x 6.5" Saab Super Aero rims
Goodyear Revspec Ducaro 205/50/16 tyres
Other
Stock Saab Aero factory whaletail
Saab Aero vent covers (factory colour coded silver to match duco)
AutoMeter 30"hg to 30psi boost guage
AutoMeter air/fuel ratio guage
Saab factory rear decor panel
SaabSavior short shifter
Saab Momo leather steering wheel
3.5mm blue silicon vacuum hose
Saab Aero original Alpine surround sound 5 speaker stereo
Aero kit factory colour coded silver to match duco
Output
Estimated 190kW (250hp) at front wheels (need to do another dyno once new crate engine is run in)
1 PICTURE!!!!
2003 Saab 9-3 SS
Specs
Engine
K&N air filter
Exhaust
Ferrita Catback Exhaust
Wheels & Tyres
18" OZ Superturismo GT Wheels
Continental Sport Contact 3 tyres
Audio
Focal speakers
MTX amplifier
ehhh ill give it a try
2011 9-3 2.0T 6MT
Specifications
Engine
Stock
Exhaust
Magnaflow muffler with dual 3" tips
Turbo
DIY open air intake
Fuel System
Stock
Suspension
Stock
Wheels & Tyres
18x7.5 BBS RK wheels with 225/40R18 Continental ExtremeContact DWS
Other
Plasti-dip grill, plasti-dip rear emblem decor panel, X-line 30-30 boost gauge dash mounted, Sylvania Silverstar turn signal bulbs in all corners, and DDM Tuning 55W 5K HID kit.
Output
Estimated 210HP factory
Storsjöodjuret (2004 9-5 Arc 2.3T)
- Swedish for "monster"
Specifications
Engine
stock B235 2.3 Litre w/Mitsubishi TD0415t turbocharger
NGK BCR8ES plugs
ETS intercooler
King Cobra inlet
GS "bolt mod" (manifold pressure)
Forge recirculating diverter valve
Exhaust
JT full 3-inch w/sport cat and oval chrome tip
Aero bumper lip w/exhaust notch
Fuel System
Bosch 3.5-BAR fuel pressure regulator
Maptun Stage 4 ECU (315hp) w/open SID
Suspension
Aero springs
Koni FSD struts
Nordic ceramic brake pads and performance drilled/slotted rotors
Maptun strut tower brace
silver G2 high-temp caliper paint
black vinyl Saab caliper logos (front)
Wheels & Tires
17" Aero 5-spoke EVO rims
Michelin Pilot Sport A/S plus 225/45/17 tires
Other
Hirsch grille
custom black griffin badges (hood, trunk, wheels)
red Hella supertone (high/low) horns
Maptun Performance badges
Shaved "9-5" and "2.3T" badges
Maptun air filter
Maptun blue silicon hoses (coolant and turbo)
blue 3.5mm vacuum hoses
Genuine Saab billet aluminum oil and coolant caps
June SOTM Submission
2007 Saab 9-3 SS - Matte Black w/Carbon Fiber Accents
Specifications
Engine
BSR Intake
Exhaust
Full CatBack Megan Racing Exhaust
Suspension
Koni Yellow Fully Adjustable Shocks
Megan Racing Springs
1.5" Drop
Wheels & Tyres
18" x 8" Enkie EKM3 Wheels
Kumho Tires
Other
JVC Navi/GPS/DVD Player
10" Custom Enclosure
Carbon Fiber Inserts Inside
Carbon Fiber Wrap Hood and Pillars
Full Custom Matte Black body
More photos on my website: http://galindophotos.smugmug.com/Oth...2858613_k5N4qk
(running out to car... wrenching... running back)... yep, they are BCPR8ES, alright. Whew.
Yep, not safe to assume - that's why that gap coin still sits in my toolbox from days of yore (I used NGK on my Nissan as well - except they were platinums).
On a side note, I do appreciate the feedback - but probably like you, sometimes there are a hundred things going on, and I had a brain fart in typing. Nitpicking sucks when it occurs (we all do it). Hope I put those pistons and cams in correctly (probably going to have an indie do it for me). Hope it runs great afterwards.
When I put the tune together, knowing how I drive, the 8's have been a great addition. Maybe I'll try the 7's next time to see how they do, who knows. :cheesy:
i think the bus just came and took you to school. dang
im gonna go check my plugs now :D
1990 Talladega SPG
Mods
Engine
2.0L 16v Turbo 5spd.
Blue series injectors
3.0 bar
Red box apc
High pressure bypass valve
18 psi wastegate
CAI
Fuel chip
Performance wires
FMIC
15+ psi of boost
Exhaust
Catless starla exhaust
Suspension
Lowering springs
Bilstine shocks
Interior
Black leather, plaid red/white/black door inserts and shifter boot.
Boost gauge on the A-pillar
Full sound system
Exterior
Talladega Red SPG
Window louvers
Blacked out front grill
1991 Saab 900 Turbo 5-speed
Unmolested original
Specifications
Engine
Stock
Exhaust
Stock
Turbo
Rebuilt Garrett T3
K&N drop in filter
Fuel System
Stock
Suspension
Stock
Wheels & Tires
16'' Aero Wheels
205/50/16 Continental ExtremeContact DWS
Other
SPG vent covers
1993 Turbo S (t16) 900 in Imola Red
Engine: Stock with red box
Exhaust: Stainless twin tailpipe from back box
Suspension: Koni red adjustables at front
Wheels and Tyres: 16 inch super aero with Kuhmo 195's
Others: Vent covers
Momo steering wheel
Dover Grey leather interior with suede inserts
Now this is going to be a tough month ... with 3 C900's in there .... Common boys ... ..sort it out ... we have to maintain domination ! ;ol;
Make that four C900s...
1987 SAAB 900i "Frenchie" Benelux model
Engine
2.0 liter, 8 valve, no turbo, fuel injected
250,000 km (155,347 miles)
Bosch distributor caps, rotor and spark plug wires
Mann air filter
NGK BCP6ES spark plugs
Clutch
Same as new, never replaced
Exhaust
Rusty, but no holes
No catalytic converter
Turbo
Just look at the rims!
Fuel system
Bosch CIS fuel injection
Bosch OEM fuel filter
Genuine SAAB OEM brittle fuel lines
Fed 95 octane because it's the only ethanol-free locally
Suspension
Soft and cushy stock suspension
Wheels and tires
US market "Turbo", aka "Manhole Cover" wheels, 15"x5.5"
185/65-15 Michelin tires
Other
ANA Trolhättan rear license plate frame
Nardi four spoke steering wheel
Leather shift knob
Motometer 3-gauge pack (volt, oil pressure, engine oil temp) on lower cubbyhole
Uncracked dash, black
Gorgeous, as-new red velour interior
Refurbed headliner
Complete factory tool kit
No rust on body
IntSAAB 2010 participant #230
1 - 20 of 30 Posts
