Hi Guys
I'm looking for help getting a screw out of my decor panel.
Prolems are..
The torx whole is to shallow due to corrosion. I managed to get the left one off using a pair of pliers. The right one seems to just spin around (i suspect that the thread at the top of the screen has corroded e.g. doesn't begin to grip as it turns).
I looked inside the tailgate hoping to find a bolt. No such luck. It seems to screw directly into a lug on the tailgate.
Does any one have any suggestions for getting the srew out.
Thanks in advance
Is this one of the screws that goes into the license plate bracket?
If so, the scew goes into a square nut behind the bracket. You loosened the screw and now the nut is spinning with it.
