Got the fill and the check plugs off but the drain plug was on there too tight. Had a very sturdy stubby 8m allen wrench, wouldn't budge. Connected it to a 1/4 inch to 1/2 inch adapter to a breaker bar. Tried to keep it straight as possible but it seems like she's stripped
As most of you know it's already a very hard to access hole to drill/dremel out. MAYBE I could fit a dremel in there to cut a hole for a flathead but I'm not too confident
I managed to suck out maybe 2/3 of a quart of oil through the check plug via mini extensions from a shop vac. It was tedious though, and took some time. I guess I could do that 3/4 times but the fluid is not very cheap
Anyone have any creative ideas/thoughts?
