1 - 8 of 8 Posts
I have re-balanced the new tired, got the car aligned and there is still a vibration in the front end. I know this could be a plethora of things but any thoughts? I am thinking wheel bearing but upon inspection they had no play or sound but I can't track this one down as of yet.
G
More info is required if we are to help you!!
Does it vibrate at speed, idle, corners, all the time, some times, vibrate fast/slow?
Thanks!!
Nothing at idle. More noticable at lower speeds. Once above 55mph it is hardly detecable. You can really hear it upon decelleration. It is not a warped rotor type of sound. It actually doesn't make the car or steering wheel vibrate like a rotor would so it seems more like a whel bearing type of noise but mot as auduble as a typical wheel bearing failure. I had one of those go on my old spg and it was very loud and very quick to happen.
Hope this helps. I am stumped.
bad motor mount?... just a guess... but i drove a 9-5 once and it would only vibrate (horribly) at lower speeds) during acceleration/decelleration and it was a broken motor mount...
Perfect timing with this post... I have the Exact same prob, just got new tires/alignement and rotated tires to no avail.
Please keep up if you find anything, i am going to check my wheel bearing and motor mount tonight.
Hello
Did you have any luck resolving this?
I have had a nasty vibration in the front end for about 6 months now. Mainly through the passenger seat but also slight vibration in the drivers seat and steering wheel at speeds of 90km/h ++. The car has 150k on the clock.
I have had the tyres/wheels checked and aligned, shock absorbers and springs checked and all came back ok. In my last service I asked them to check it and they said the hub was a bit loose and they tightened it but this had no effect.
Im running out of options so if anyone has some ideas that would be appreciated.
What happened with mine was a bent wheel on the passenger side (which went flat on my thanksgiving trip across state) and a bad wheel bearing on the drivers side.
The vibe is much better now, but still there (prob from bent wheel).
Have your mechanic check the wheels bearings; if there is a heavy jiggle in your shifter (manual) it might also be a motor mount.
1 - 8 of 8 Posts
