Hello,
I have a 03 sport sedan 1.8t which is having starter problems for a while and i cant figure it out myself, the problem occurs when the car is cold never when it is warm.
So i replaced the starter a year ago (aftermarket) for this problem and last month i put a new battery in (Bosch005) because the problem got worse/back, it seemed fine for some time just like the previous year and i thought it fixed it.
Last night i visited my father and when i tried to leave the same old problem occured the starter wont engage i hear all the normal sounds it just doesnt engage the starter the engine was offcourse cold because it seems to only happen when it is cold. There are no messages/codes i want to test the resistance of the earth and i will but i dont think that is the problem because i cleaned the connections under the battery.
So to summarize, no crank when cold but only sometimes, the car started fine 2 times half an hour ago now i would think it is just the starter but it does start after i reset the ecu and tapping the starter does nothing. I found out there is a ignition control module could this be faulthy? i would really appreciate if someone send me in the right direction it is giving me a real headache.
